I was wondering if there is a plot stamp option in inventor, like there is in autocad?
Thank you
Solved by Curtis_Waguespack. Go to Solution.
Hi hawkinsCadGuy,
If you use the Search tool, you'll find several related posts:
I hope this helps.
Curtis
See if this thread helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Plot-Time-amp-Date-in-Plotstamp/td-p/2837331
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you Curtis!! Your the man, those links helped me solve my plot stamp problem
