I created view representations in my assembly, for example a column with k-polates and base plates, the column is a FG part, so now i create drawings and place views on that drawing, what i am askign for is I want to place the name of the view representation in my view label as a paramater so in the event i change my view names in my model they update in my drawing, this is important because i can create a cross referance to my 3D DWXF file views.
Adrian.
Please review the below link. It offers a potential solution.
http://forums.autodesk.com/t5/Autodesk-Inventor/Representation-View/td-p/3112742
Cheers,
Can you clarify which method you are using from the post? I tested using a simple example with the ilogic code initially provided.
