I would like if somebody helps me whit this issue, I want to know if is possible to create a troquel punch as iFeature for just bend, not cut o drilled, for example, to create a squared punch for to make a bending in a sheet metal,
I hope you can understand me
Tks.
I don't think you would be able to do this and then unfold it. Your best approach may be to sketch,pattern and then contour flange if you are doing panels like that.
