Inventor Forum
Is Limit mates possible
7 REPLIES 7
Message 1 of 8
CAD-One
1371 Views, 7 Replies
I need to know if there is a way of constraining an angle with minimum and maximum between 2 parts.
Example :
1. Say, I have a Rectangular Box and a lid. The lid has an axis mate with the box and can now rotate about this axis.
I want to provide an angular mate so that the door can be flushed to box (0 deg) and open (90 deg)
2. I have seen several inventor examples demonstrating Position reps for a product like a cylinder and piston's open & closed positions.
I want to know if we can set a min and max so that we can have the piston positioned any where between these 2 limitis.
Thx
C1
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: CAD-One
You can RMB - Drive Constraint the angle between upper and lower limit.
Or you could set up a Contact Set (if natural limits don't exist you might have to create a hidden dummy component). If you can't figure out either solution zip and attach what you have so far.
Message 3 of 8
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 4 of 8
CAD-One
Kudos Dennis. thanks for sharing this. I dont understand why Autodesk should object this kind of application.
C1
AutoCAD 2020
Message 5 of 8
CAD-One
I understand the benefit of Drive constraint. The disadvantage, in my opinion, is that I need to return to the drive constrain dialog always. I wanted to perdom by just point and drag.
C1
AutoCAD 2020
Message 6 of 8
Drew, the originator of this tip felt that this functionality
might be removed in the future. I don't see that happening any time
soon.
Expert
Expert.
PcCillin AV
XP
Message 7 of 8
Just go into your constraint dialog box, click the arrow for "more", and set a minimum and maximum value for any constraint in the boxes provided.
Message 8 of 8
JDMather
This functionality was added to Inventor since the initial post several years ago.
