In a project I'm working on I need to make the text have mirror properties. But when editing the text all i can choose from is "normal" colors.
So is there any way to make text use materials, like you do on normal surfaces?
Solved by CCarreiras. Go to Solution.
Can you post file?
Is this sketch text, feature, drawing?
Thanks for the really quick answer! Like you said, if I choose like 0.001mm it's not even going to be noticeable.
You can do Split on the face and have zero (0) offset.
The only problem is you have to do it for each letter.
