Inventor Forum
is it possible to rename the YZ, XZ & XY planes
6 REPLIES 6
andrew.nao
699 Views, 6 Replies
i would like to rename the default YZ, XZ & XY planes to say "front", "top" & "side" and keep it like that everytime i start a new part or assembly is this possible? i thought it was in the options but i dont see it am i missing it?
6 REPLIES 6
mcgyvr
in reply to: andrew.nao
no..
do you have the "view cube" turned on? Its already got front/left/top..blah blah blah..
http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/...
ampster401
While you can rename the default workplanes just like user created workplanes, I don't know if you did that within the template files (and saved them as template files) if it will stick or not.
Try it.
mcgyvr
in reply to: ampster401
Try it.
ah yes.. maybe thats what he meant.. doh...
I was assuming for some reason the origin 3d indicator..
swalton
I renamed the orgin planes in my part template files years ago.  I had to wait until we moved to IV 2014 to rename the orgin planes in the assembly templates.
Steve Walton
Inventor 2023
Vault Professional 2023
chrisjuk12
Hi Andrew,
You can permanently change the names of the origin planes by renaming them in the part file then saving that part as your standard template.
1. Rename planes
2. Application button>Save as>Save as template>standard.ipt
Chris
andrew.nao
in reply to: chrisjuk12
thank you
