Solved by mcgyvr. Go to Solution.
Hi! As of Inventor 2015, there are three ways to create notes directly on a model. In an assembly and a part, you can simply select a piece of geometry -> right click -> create Engineering Note. You can also create Welding symbols on a weldment assembly. There are API calls available to create some 3D annotations in part and assembly.
Thanks!
sadly no..
Some of us have been requesting whats commonly referred to as 3D PMI (or MBD model based definition) from Inventor for years now. Standardized in ASME Y14.41 and a few others.
They had a tool on the labs site a few years back called 3DA or 3d annotation that did it but I think its been retired now.
There should be a request in the Inventor ideastation.. but I can't find it now.. searching through that is sub par IMO..
found it.. http://forums.autodesk.com/t5/inventor-ideastation/3d-gd-amp-t-annotations/idi-p/4377399 (show your support please by giving it a kudo)
Its available in most other CAD packages now but sadly Inventor is behind the times on that one..
Solidworks got it this year I think so I'd expect (hope) Inventor to follow soon..
http://www.solidworks.com/launch/documents/sw2015_launch_mbd_eng.pdf
Its how all future cad will be.. I just don't see the point of 2d drawings anymore.
All our vendors mostly use my 3d models and the 2d drawings are just for tolerances/notes which would easily be accompished in a 3d PMI/MBD
"All future CAD..." You really should consider that your experiences are not the extent of possibility.
P&IDs, PFDs, MFDs, single-line diagrams, PLC ladder logic diagrams, grounding schematics, yadda yadda yadda. Not everything can be well represented in 3D, and not all 3D is well represented on hardcopy.
Well yes.. I intended that to be "Inventor" related CAD..
Not schematic capture/diagramming type programs,etc... I don't consider that "CAD"..
Any fabricated/molded,etc.. part can easily/completely be documented in a single 3d file with 3D PMI
Even 2d drawings for assembly purposes,etc...
and I should have said the "next main step/direction" in cad. The next major change/focus
2D CAD drawings are simply an old dinosaur to me on the edge of extinction. A single 3d annotated file is all that should be required/shared.
I am adding component tags with ilogic.
This is how I add tags to my equipment.
http://blog.ads-sol.com/2014/10/part-tagging.html
http://blog.ads-sol.com/2014/08/component-tags-in-inventor.html
While you're there check the video as well, you might get a better idea on how that works.
https://www.youtube.com/watch?feature=player_embedded&v=r0NuTAwpYFk
