Is it possible to move a 2D sketch vertically? I have a sketch on the XY plane, but I'd like to move it up to another entity.
I can see how to do it in 2D (in the XY) plane, but not along the X axis.
Solved by CCarreiras. Go to Solution.
Hi!!
If you do it in the XY plane, you cant do that, because you cant move the original planes, axis and center point.
But... if you do your sketch in a new work plane, you can vary the "vertical" position of that plane, and so, the skecth come with the plane for a new "vertical " position.
If you have a sketch in a plane, and want to repeat tha sketch in another plane but in a different "vertical", along the Z axis, first you create the plane in that vertical position and then, open a new sketch and copy the original sketch by using the "project geometry tool". Both sketchs will remain associative.
Regards.
