Inventor Forum
Is it possible to move a 2D sketch vertically?
3 REPLIES 3
oransen
3004 Views, 3 Replies
Is it possible to move a 2D sketch vertically? I have a sketch on the XY plane, but I'd like to move it up to another entity.
I can see how to do it in 2D (in the XY) plane, but not along the X axis.
Tags (1)
3 REPLIES 3
CCarreiras
in reply to: oransen
Hi!!
If you do it in the XY plane, you cant do that, because you cant move the original planes, axis and center point.
But... if you do your sketch in a new work plane, you can vary the "vertical" position of that plane, and so, the skecth come with the plane for a new "vertical " position.
If you have a sketch in a plane, and want to repeat tha sketch in another plane but in a different "vertical", along the Z axis, first you create the plane in that vertical position and then, open a new sketch and copy the original sketch by using the "project geometry tool". Both sketchs will remain associative.
Regards.
solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
CCarreiras
mrattray
You could also RMB on the original sketch and use "redefine" to change the plane that the sketch uses. The sketch will usually need some repair work afterwards, but leaves you with one sketch where it belongs instead of two.
Mike (not Matt) Rattray
oransen
in reply to: mrattray
Thanks for the tip, I'll try it. I had to look up RMB though (Right Mouse Button)!
