Inventor General Discussion
hhls11
Message 1 of 4 (312 Views)
Is it possible to create a weld build up around a part?
312 Views, 3 Replies
10-05-2012 07:31 AM
I'm starting with a tube and want to add a weld build up around the OD on both ends. I mainly want to do this so that when I create a sectioned view on a drawing, you can see the difference in hatching between the original tube and the weld build up. I've had to create sketches on the drawing up to this point, but that's kind of a hassle. Is there any way of doing this?
The photo I've attached shows the tube and shape of the weld build up. the green line is where I would like the tube OD to be, and the weld build up would be everything above that.
I'm using Inventor Pro 2013.
Thanks in advance.
Inventor Professional 2013
Intel Xeon W3680 @ 3.33Ghz
12GB DDR3 RAM
NVIDIA Quadro 2000 GPU
Windows 7 Professinal 64-bit
Distinguished Contributor
Ryan.Martinez
Message 2 of 4 (294 Views)
Re: Is it possible to create a weld build up around a part?
10-05-2012 07:59 AM in reply to: hhls11
Call it out with a note?
PDS 2014
PDS 2015
harco
Message 3 of 4 (292 Views)
Not sure without trying but the split tool may give you what you want.
If not use a very thin cut to give an edge.
Valued Mentor
japike
Message 4 of 4 (282 Views)
10-05-2012 08:18 AM in reply to: harco
Add the weld build up to your part as a new solid body.
Peace,
Jeff
Inventor 2013
