Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Is it possible to change the texture of the hatched area on an IDW?
2 REPLIES 2
355 Views, 2 Replies
The part I am detailing is a cast iron part, and I have appropriately changed the material appearance to match. On the IDW, a section view shows in the hatched area the same material as the non-hatched area. BUT, as we know, when we cut a cast iron part in half, the cut section of the part looks different then the outside.
Is there a way I can change the material appearance of the sectioned area of the part on the IDW, so it appears more obvious that it's a cut section?
2 REPLIES 2
mpatchus
There is no automatic way to override a texture on a section face (that I know of).
One work around, although a bit tedious and annoying) would be to split the solid where you are going to create the section and apply a color override to the face.  Then align your section line with the split.
I wouldn't want to have to do this for every part I make, but in the odd instance it would be okay.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. šŸ™‚
in reply to: mpatchus
That will work perfect for this instance. Thanks for the suggestion!
