Has anyone seen such behavior?
I have a file in my purchased part library on a network drive. When opening in IV8 I get: 'Error reading RSe stream' followed by '[ERROR] Invalid parameter error. '
When I try to copy the file in Windows Explorer I get: 'Error Copying File or Folder: Cannot Copy A-53.ipt: The parameter is incorrect' I renamed then tried a copy, same result.
I can move the file to another directory on the same drive letter, but get 'parameter is incorrect' when trying to move to a local drive or different drive letter which is basically a folder on the same physical network drive.
I can do an iProps on it, change status, apply, it saves the change (I can see the modified date update). Besides that, I can only rename or delete it.
Also tried a suggestion of copying it in dos prompt... no luck.
Is there a way to recover it?
Andrew
