Inventor General Discussion
justinvoltz2417
Message 1 of 6 (1,751 Views)
IPT File > DWG or DXF File
1751 Views, 5 Replies
03-22-2011 01:16 PM
Hello I'm having trouble making a DWG or DXF file from a IPT file. I use Autodesk Inventer Professional 2011. I'll give you a run down as to what I do to......
Once my part is designed in Inventor I do:
-Save as
-save copy as
-and I go to click on DWG or DXF but I do not have that listing.
Ive attached a screenshot. Any suggestions?
Environments>AEC Exchange>Save as DWG Solids.
Hello: I wish to save my 2D drawing as a DXF in inventor.
Currently, I save it as a DWG in inventor as you said above and then converted it in AUTOCAD to a DXF.  I will continue to do this unless it's an option in inventor.
John
Simply Save Copy as type dxf.
or
if the part is flat you don't even need a 2d drawing.  Simply click on the face and select Export to dxf.
http://www.eng-tips.com/viewthread.cfm?qid=294976&page=1
Wow, thanks that works great! I really appreciate the help.
Inventor is a great program.
John
I need to save a dwg into inventor 2011. not having any luck. Any suggestions would be wonderful
JDMather
Message 2 of 6 (1,748 Views)
Re: IPT File > DWG or DXF File
03-22-2011 01:20 PM in reply to: justinvoltz2417
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
galba1
Message 3 of 6 (1,701 Views)
03-23-2011 07:46 AM in reply to: JDMather
John
JDMather
Message 4 of 6 (1,695 Views)
03-23-2011 07:55 AM in reply to: galba1
or
Member
galba1
Message 5 of 6 (1,679 Views)
03-23-2011 08:17 AM in reply to: JDMather
John
New Member
rowemanDJ88
Message 6 of 6 (1,544 Views)
06-10-2011 10:55 AM in reply to: justinvoltz2417
