"Sean Dotson" <sean at sdotson dot com> wrote in messageNew
href="news:9C2B53346075A87D9A6AC0D52B1F53C0@in.WebX.maYIadrTaRb">news:9C2B53346075A87D9A6AC0D52B1......
custom properties?
Create the new custom property in a file and then
use the setup wizard and
add this property to the list.
Be sure to
check the "Create Custom Props if not Present"
When you open a file
that does not have this property it will be shown in
red...When you click
Apply they will be added to the file.
Is this what you
meant?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
"J.CROTEAU"
<jc@lan.com> wrote in message
href="news:f183722.-1@WebX.maYIadrTaRb">news:f183722.-1@WebX.maYIadrTaRb...
I was wondering, if I create new propreties how can I insert them in my
old
drawing.
"RuiF" <rui.cad@netcabo.pt>
wrote in message
href="news:503BB64FB58C60F049C97E9BA8AEFF74@in.WebX.maYIadrTaRb">news:503BB64FB58C60F049C97E9BA8A......
Just a few questions regarding your
answer:
You create the properties in, say, a new part
file.
Then what exactly is the "setup
wizard"?
RuiF
href="news:9C2B53346075A87D9A6AC0D52B1F53C0@in.WebX.maYIadrTaRb">news:9C2B53346075A87D9A6AC0D52......
custom properties?
Be sure to
Is this what you
meant?
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
"J.CROTEAU"
my
old drawing.
"J.CROTEAU" <jc@lan.com> wrote inYes
message
href="news:f183722.1@WebX.maYIadrTaRb">news:f183722.1@WebX.maYIadrTaRb...
it was, also can I use desing assistant to copy my new prop to old drawing.
Thank you for the quick answer.
"Sean Dotson" <sean at sdotson dot com> wrote in messageHave
href="news:18F6A4B2E84CE12090904E5CC9F09D11@in.WebX.maYIadrTaRb">news:18F6A4B2E84CE12090904E5CC9F......
you downloaded the program? If so read the instructions. It's
pretty
easy.
Sean Dotson, PE
Check the Inventor
"RuiF"
<rui.cad@netcabo.pt> wrote in
message
Just a few questions regarding your answer:
> You create the
properties in, say, a new part file.
"setup wizard"?
> RuiF
> "Sean Dotson"
New custom properties?
property in a file and then use the setup wizard
and
> Be sure to check
> When you
open a file that does not have this property it will be
shown
in
> red...When you click Apply they will be added
to the file.
> Is this what you
meant?
> Sean Dotson,
PE
Check the Inventor FAQ for most common questions
message
in
my
> old
drawing.
