I want to create a Text Custom iProperty that will get the value of the Thickness Parameter without the trailing zeros and decimal point.
At first I simply exported the Thickness Parameter, but then it would show in the Custom iProperties with the precision stated in the document settings.
Please Help.
Yoni
Solved by PaulMunford. Go to Solution.
In the parameters manager, once you have marked the parameter for export, you can right click in the appropriate cell and chose 'Custom Format'.
This will allow you to have one paramter value display differntly to the defult part document units
Thanks Paul,
Your post was most helpful.
So simple, but never accured to me...
Yoni
