Hi there, We would like to enforce that our designers save all Inventor files by the Part number only. This is not a problem when using Vault to open files as the interface can be customized to show the iProperty description field. The problem comes in for users who open files from the local drive before they have been added to Vault. There is no way for them to see the iProperty descrition for the files except if they hover over each file and wait for the tooltip to show which then shows a number of iProperties.
I found that I can add a Windows description column but by default it is blank. Is there anyway to get the iProperty description to synchronize with the windows description column? If not does anyone out there have any other suggestions?
This is a limitation at the moment. iProperties of Inventor files cannot be added into the Windows Explorer column list. We have a wishlist item logged to our development team about this.
And it's a big problem when you're using e.g. productstream or any other PDM software, and all od you like 100 000 parts are ENG-9457747 format. To be able to get iproperties and custom iproperties somehow into windows, would be awesome!
Has there been any progress on this? I noticed when you use the "open" command within Inventor, you CAN choose the "description" column, however nothing is populated in the fields. Does anyone have any insight on this?
Seems there is an idea station request for this.. (author field but some of the comments request "any iproperty" to be added)
Show your support for it here by voting it up..
You can also use Inventor Design Assistant in Windows Explorer to see your preferred iProperties.
See the explanation I posted here:
