Inventor Forum
iProperty description field in Windows explorer
9 REPLIES 9
Message 1 of 10
wseaston
2064 Views, 9 Replies
Hi there, We would like to enforce that our designers save all Inventor files by the Part number only. This is not a problem when using Vault to open files as the interface can be customized to show the iProperty description field. The problem comes in for users who open files from the local drive before they have been added to Vault. There is no way for them to see the iProperty descrition for the files except if they hover over each file and wait for the tooltip to show which then shows a number of iProperties.
I found that I can add a Windows description column but by default it is blank. Is there anyway to get the iProperty description to synchronize with the windows description column? If not does anyone out there have any other suggestions?
9 REPLIES 9
Message 2 of 10
Daniela_Koloszko
in reply to: wseaston
This is a limitation at the moment. iProperties of Inventor files cannot be added into the Windows Explorer column list. We have a wishlist item logged to our development team about this.
Daniela Koloszko
Message 3 of 10
mrice
in reply to: Daniela_Koloszko
Would be great to see this item off the wishlist soon, like the next update to 2014 (if there is another one). This is currently a headache and frustration!
Message 4 of 10
streharg
in reply to: mrice
And it's a big problem when you're using e.g. productstream or any other PDM software, and all od you like 100 000 parts are ENG-9457747 format. To be able to get iproperties and custom iproperties somehow into windows, would be awesome!
PDSU 2016
4790K, 32 Gb ram, GTX 960 ...
Fancy HP LCD
Message 5 of 10
stephengibson76
I know its an old post...  Is this possible yet?
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 6 of 10
chrisw01a
in reply to: stephengibson76
Has there been any progress on this?  I noticed when you use the "open" command within Inventor, you CAN choose the "description" column, however nothing is populated in the fields.  Does anyone have any insight on this?
Message 7 of 10
chrisw01a
This would be a huge help when looking for an inventor file!
Message 8 of 10
mcgyvr
in reply to: chrisw01a
Seems there is an idea station request for this.. (author field but some of the comments request "any iproperty" to be added)
Show your support for it here by voting it up..
https://forums.autodesk.com/t5/inventor-ideas/make-author-info-visible-through-windows-explorer/idi-...
Message 9 of 10
chrisw01a
in reply to: mcgyvr
Will do. Thank you.
Message 10 of 10
JBerns
You can also use Inventor Design Assistant in Windows Explorer to see your preferred iProperties.
See the explanation I posted here:
https://forums.autodesk.com/t5/inventor-forum/iproperties-in-windows-explorer/m-p/6674560/highlight/...
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
