We have been using the Hex Bolt Iparts downloaded from the CBliss.com site many years ago and we have just dealt with the fact that Iproperties are not correct.
We are finally trying to get our BOM's spot on and these same Iparts are giving me fits....I don't seem to be able to get the right size to show up without breaking the link to the Ipart factory and entering them in manually for each part in Iproperties.
Am I sunk?
Does anyone have a UNF and UNC Hex Bolt Ipart factory they would like to donate to the cause?
thanks!
Solved by 4donwan4. Go to Solution.
What EXACTLY are you trying to do?
You need to put the iproperty column in the ipart table to have unique values then generate all members.
I am not sure as to the issue your having either. Try something from scratch if need be as it might be an issue with that file?
Don
Ya, this is an Ipart that was downloaded many years ago and it just won't work.....just trying to save some time and use it. oh well,
thanks!
