Inventor Forum
iProperties (some strings) rewritten on save.
6 REPLIES 6
302 Views, 6 Replies
Do you guys know what is the problem when some parts of iProperties are rewritten when an assembly/drawing is saved?
My problem is with the iProperties > Summary > Description field
The cotents of this filed is called to a table (see attached picture). When I try to modify it it works and the data is written as I want. But when I save and reopen the drawing/assembly, the text is changed back to original - blank.
What is wrong?
6 REPLIES 6
Are you modifying the description field in the drawing table? You need to enter it in the iProperties.
No I am not trying to modify it in drawing table, but through iProperties. But it is erased when I save and reopen file.
Check document settings, Drawing tab, Copy Model iProperty Settings.
The "Copy Model iProperties" is unticked.
I activated the description and still nothing. When I enter a text in dexcription field it appears in drawing table. But as soon as i hit "Save" it is erased again (actually replaced by the original text) - how do I prevent it from modifying that on save?
salariua
post the file here. There might be some ilogic forcing it back.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
in reply to: salariua
Unfortunatelly it is confidential. However this was the solution - an iLogic script was rewriting the description. I have found it and disabled it. Thanks
