Inventor Forum
iProperties Precision
9 REPLIES 9
Message 1 of 10
andrewdroth
213 Views, 9 Replies
I have text in an .IDW that refrences an assembly custom iProperty. That custom iProperty is an exported assembly parameter.
Right now I have the text displaying "40.000 Lbs".
Is there a way to truncate the string to cut off the unit and precision to show "40"?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
9 REPLIES 9
Message 2 of 10
RonnieWilkins
in reply to: andrewdroth
In '09 yes.
Ronnie Wilkins, Jr.
Message 3 of 10
andrewdroth
Sweet!
But that means no in '08?
Andrew Roth
rothmech.com
Message 4 of 10
mflayler2
If it is in a Parts List you might try Value Substitution and change the units or precision.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 5 of 10
andrewdroth
Nope, its text in a sketch.
Andrew Roth
rothmech.com
Message 6 of 10
mflayler2
Just curious, what is the reason for the 40 LB weight? Is it needed as a conversion, for reference of something in the assembly, etc. You are not trying to get the Total Assembly Mass this way are you? (There are easier ways)
Message 7 of 10
andrewdroth
Nope not the mass.
Its a drawing of a lifting device. I want to show a stamp of the capacity in the drawing. When the capacity changes I would like the text in the drawing to change as well.
The capacity it actually 80000 lbs but I used a paramter to divide it by 2000 to give me Tons. So now I have it showing up as "40.000 Lbs" and I would like to keep the "40" and add more text to give me "40 TON S.W.L., were the '40' will change with the capacity parameter.
Andrew Roth
rothmech.com
Message 8 of 10
pkquat
To get rid of the "lbs" you should be able to change your units to "unitless" and adjust the formula ie X lbs / Y lbs * 1ul. There was a post on how to get rid of the trailing or leading zeros. I think you can change the format from text to number. If you want to change the displayed precision in '08 then I think you will need the LeaCar Mini-PE.
www.leacar.com
Pete Message was edited by: pkquat
Message 9 of 10
dan_inv09
a. Isn't there a precision window in the text dialog? You might need to designate your custom property as type "number." Can you change that with exported parameters? Since no one's suggested it I would have to guess, "No."
b. Well there was going to be a b but I just checked and "ton" is not a valid unit type. You can have pico-lumens or tera-teslas but not tons, go figure.
Okay, this probably won't help either. "Stamp," like rubber stamp, or like stamped into the part? If you emboss (or just extrude if it doesn't need to wrap) it on the part you can work directly with the parameter. Come to think of it, can't you do that in the drawing too? I think you can access the assembly parameter directly without exporting it, and then you can set the precision.
Message 10 of 10
andrewdroth
Changing the 'TYPE' in the custom iProperties window to 'number' worked.
Thanks for all your ideas.
To clarify, the 'Stamp' was stamped into the part. I tried using emboss, but the outcome on the drawing was an outline of the text. I wanted it to be filled black.
I was also doing the text inside a sketch on a view. I think you can only access the custom properties when your in a sketch. Message was edited by: andrewdroth
Andrew Roth
rothmech.com
