Inventor Forum
iProperties in Title Block
2 REPLIES 2
jostroopers
396 Views, 2 Replies
I want to use the Filename property in my title block.
But i don't want to see the .dwg extension.
Is it possible to not show the extension?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
2 REPLIES 2
BLHDrafting
in reply to: jostroopers
1 solution would be to use <PART NUMBER> as it seems to always be the same as filename less the extension. That's what I do in my IDW template.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
jostroopers
I use the iLogic code: iProperties.Value("Custom", "Filename") = ThisDoc.FileName(False) 'without extens
Now the .dwg is not showing.
Mvg Jos
