Inventor Forum
iProperties - Design Assistant - Detail Tab
4 REPLIES 4
Lancasterm
530 Views, 4 Replies
When you look at iProperties In Design Assistant (and Windows) of an Inventor file you have a "Detail" tab that allows you to see which Inventor version created it and when it was last updated.   Is there a way I can pull that information in so I can see it while in Inventor & looking at the part?  Or is there some program code that already does that?
Inventor 2015 Pro SP1
4 REPLIES 4
Hi Lancasterm,
Here is a quick iLogic rule that you can run to get this information:
On second thought, this gives the version and build of Inventor you are running, not the version of the file. Smiley Sad  Off I go to search...
sVersion = ThisApplication.SoftwareVersion.DisplayName
MessageBox.Show(sVersion, "Version Info")
'write out the info to the comments iProperty
iProperties.Value("Summary", "Comments") = sVersion
 I hope this helps.
Curtis
Hi Lancasterm,
Here is an iLogic rule to find the file version created and saved information.
I hope this helps.
Curtis
oCreated = ThisDoc.Document.SoftwareVersionCreated.DisplayName
oSaved = ThisDoc.Document.SoftwareVersionSaved.DisplayName MessageBox.Show("This file was created with: Inventor " & oCreated _ & vblf & "This file was lasted saved with: Inventor " & oSaved, "iLogic")
Curtis
Thanks..  Exactly what I was looking for...
Maxim-CADman77
in reply to: Lancasterm
What about reading "Previous Version" iProperty value?
