Can sameone can help how to keep the Author and Designer name as capital letter
Solved by Curtis_Waguespack. Go to Solution.
Hi avi120,
You can go to the Tools tab > Application Options button > General tab and retype the entry for the User Name setting using all CAPS.
I hope this helps.
Curtis
