Inventor Forum
iParts...
15 REPLIES 15
Message 1 of 16
926 Views, 15 Replies
iParts...
when making an iPart of a rod with only varying lengths, is it possible when
bringing it into an assy to type in a value for the length rather than
creating it first in the table? creating lengths on the fly seems more
productive than making like 100 predetermined sizes in a table.
Mark A. Bystry
Engineer
Ziggity Systems, Inc.
mbystry@ziggity.com
15 REPLIES 15
Message 2 of 16
Look into custom iParts AKA iPart Templates. Thats what you are describing.
Read my FAQ 9407 for more info http://www.mymcad.com/
I'm sure Sean has stuff on his site too. www.sdotson.com
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @
"Mark A. Bystry" wrote in message
news:F01A50ED1CB79843E9C4AAD490ADCA3D@in.WebX.maYIadrTaRb...
when
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
Message 3 of 16
yes, look at Custom Parameters in iParts...
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Drew Fulford" wrote in message
news:1439E9E1A0F3605ED94598EDBB890E31@in.WebX.maYIadrTaRb...
describing.
> - drew
> when
> > Mark A. Bystry
> > Engineer
> > mbystry@ziggity.com
Message 4 of 16
ahhhh...that's exactly what i was looking for. that works great. thank-you.
Message 5 of 16
wait...now i get an error..."column or cell is tagged as both custom value
and as key: #0"..."too few keys in the table". how do i prevent this? all i
have in the custom property field is the length of the pipe.
Mark A. Bystry
Engineer
mbystry@ziggity.com
describing.
> - drew
> when
> > Mark A. Bystry
> > Engineer
> > mbystry@ziggity.com
Message 6 of 16
Your custom property column cannot also be a key. Try that, if it still
doesn't work post it to CF and I'll have a look.
Sean Dotson, PE
news:0E2BA43983311A449C7ABA47CC0E9CD2@in.WebX.maYIadrTaRb...
i
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
> describing.
> > - drew
possible
> > when
> > > Mark A. Bystry
> > > Engineer
> > > mbystry@ziggity.com
Message 7 of 16
...it's not a key by default. for instance, when we bring over the length
parameter, a key icon is made. we click on the icon and by default, the "Do
Not Make a Key" is already checked...
Mark A. Bystry
Engineer
mbystry@ziggity.com
"Sean Dotson" wrote in message
news:1E5E6C6A166C5E3B5D78AE21C5FC5A44@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
value
all
> i
> > Mark A. Bystry
> > Engineer
> > mbystry@ziggity.com
> > describing.
> > > - drew
> possible
> > > when
than
more
> > > > Mark A. Bystry
> > > > Engineer
> > > > mbystry@ziggity.com
Message 8 of 16
that is normal. Do you have a key defined elsewhere such as part # or name?
Sean Dotson, PE
news:D68B1D9F242BB6F38B6E3D6B6A3C7F7A@in.WebX.maYIadrTaRb...
"Do
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
> > Sean Dotson, PE
> value
> all
> > i
> > > Mark A. Bystry
> > > Engineer
> > > mbystry@ziggity.com
> > > describing.
> > > > - drew
> > possible
> > > > when
> than
> more
> > > > > Mark A. Bystry
> > > > > Engineer
> > > > > mbystry@ziggity.com
Message 9 of 16
...well, yes and no. we want the part number and description to be added
eventually, but it is not defined yet in the ipart table. we are just trying
to get one parameter to work without errors first. the part number and
decryption, however, is filled in in the iproperties section.
Mark A. Bystry
Engineer
mbystry@ziggity.com
Message 10 of 16
try filling in one columns (part #, description etc..) with just garbage
(but unique garbage) like 1,2,3,4 etc.. and set that as a key to test.
iParts are a bit finicky till they are completely done.
If you post it I can take a look
Sean Dotson, PE
news:7AB12CC896BD1CD6DFC8507BEBA4D40C@in.WebX.maYIadrTaRb...
trying
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
Message 11 of 16
i have posted it in customer files...
Mark A. Bystry
Engineer
mbystry@ziggity.com
Message 12 of 16
I have replied in CF. By setting one column to a key it works. You need to
have at least one key column when using custom parameters in iparts. Each
row in the custom parameters column should be the same value (since you are
going to edit it anyway).
Sean Dotson, PE
news:BA0AD0E43FE6713F1212EABB43E0C9A2@in.WebX.maYIadrTaRb...
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
Message 13 of 16
yup. we just figured that out. we used something like our company name
(something that would never change). works fine w/o errors now. thanks sean.
Mark A. Bystry
Engineer
mbystry@ziggity.com
news:A7D8D63B1CB06FCF446E469C21224AAC@in.WebX.maYIadrTaRb...
to
are
> Sean Dotson, PE
> > Mark A. Bystry
> > Engineer
> > mbystry@ziggity.com
Message 14 of 16
You mean your company name in the length column? That won't work. It will
need to be a valid length...(1in, 2in etc..)
Sean Dotson, PE
news:55F47338EB408CAB8997BFBAB0BA5EBB@in.WebX.maYIadrTaRb...
sean.
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
need
> to
Each
> are
> > Sean Dotson, PE
> > > Mark A. Bystry
> > > Engineer
> > > mbystry@ziggity.com
Message 15 of 16
no...the "company" property in iProperties. if i add that to the table
(after i put some info in through iProperties) and then make it key 1
everything works fine. basically, i must do what you have already stated.
make a key first than add you aother fields...
Mark A. Bystry
Engineer
mbystry@ziggity.com
Message 16 of 16
OK, yes if you make it the key it will work out fine. Just realize that you
won't be able to have each part have a custom description if you have non
unique keys. There will only be one listing in the tree table.
Glad you got it working...
Sean Dotson, PE
news:292791F9E90A782C71CFBA5F81263629@in.WebX.maYIadrTaRb...
> Mark A. Bystry
> Engineer
> mbystry@ziggity.com
