Actually David that code is to change an Inventor Content Library part to a
normal part.
To change an iPart to a normal part open the child and delete the table from
the browser.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"David Deupree" wrote in message
news:87EACCBF1B32B25CB1CF76DF8A5B7299@in.WebX.maYIadrTaRb...
> Check out www.cbliss.com. In his code section, there is an i-part to
normal
> part converter. As far as constraining, I am not too sure how to
accomplish
> that. There is a way to at least keep the parts grounded with a sub at
that
> same location on Charles site....
> -Dave
> "Ronald van der Meulen" wrote in
> message news:BECF3012E64C6BD39224761D48CAB2D8@in.WebX.maYIadrTaRb...
> > Is there a method to convert Iparts to normal parts e.g. replace without
> > losing the constraints?
> > I have a huge performance problem with an assembly with lots of Iparts..
> Its
> > running on a Dual xeon
> > 2.4 GHz with 2Gig dual DDR mommory with a Quadro 900XGL Graph card. The
> > assembly is build with
> > Iparts and the total count is above 2000 placed components divided in
lots
> > of sub-assy's. I'm getting a lot of
> > forced exits when I'm modeling in the entire assembly... I run Inventor
> 5.3
> > SP2...
> > ronald.van.der.meulen@wadcon.nl
> > http://www.wadcon.nl
