in iParts factory I would like to create part ## by setting common name and adding to it different values drawn from part parameters.
Please refer to attached image – common name in that example would be “DRILL” and description of the diameter and length automatically taken from parameters in columns “DRILL_D” & “INSERT_L”.
Try this in your Part Number column:
=Drill-<drill_D>-<insert_L>
The dashes can be substituted with whatever you want, spaces or other characters. Hard to test this without having your ipart to play with but this should point you in the right direction at least. Good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi 2grumpy,
How about utilizing an iLogic rule to update Part Numbers? Here's something off the top of my head:
Dim string1 As String
Dim string2 As String
Dim string3 As String
string1 = d0
string2 = d12
string3 = "DRILL " + string1 + " x " + string2
iProperties.Value("Project", "Part Number")=String3
