Inventor General Discussion
New Member
9501215
Message 1 of 2 (268 Views)
iParts not working "Failed to export desel table" please help
268 Views, 1 Replies
05-12-2012 08:15 AM
Hey, I'm trying to use iParts but when I go to save it says this message in a popup window.
I am running Windows 7 64bit, Autodesk Inventor 2012 (free student if that affects it) and I have Microsoft Office Home and Student 2010 Installed (full paid version).
My computer came preloaded with a trial for Office 2007 when I got it but that expired ages ago, but when I went to save in iParts it would attempt to load the blocked/expired trial excel 2007 but wouldn't open due to it being expired.
I have completely rid the computer of it and even 'repaired' Office 2010 and reinstalled Inventor but to the same result.
Have looked for the registry key edit trick but this is a 64bit so it wasnt even there.
If anyone knows how to fix this please let me know as I would be extremely grateful as I don't know why it's not working and I have alot of uni work to do involving iParts.
Cheers, Luke.
Valued Mentor
Mason-Paul
Message 2 of 2 (253 Views)
Re: iParts not working "Failed to export desel table" please help
05-12-2012 11:38 AM in reply to: 9501215
As Inventor is attempting to call a now removed program, it looks like a problem in the Windows Registry
First try doing a repair of both Inventor and MS Office to see if the links change.
Then I would advise you to obtain a registry cleaning program, there are several free ones, or if you already have one of several system management programs such as Norton utilities, System Suite etc there will be a option in there to clean the registry of entries for un-installed programs that sometimes get left behind by the un-installer.
I DO NOT advise the use of the Regedit command to attempt to do this manually, the Windows registry big and complex with the same entry in many different locations One wrong deletion can totally screw your system big time.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
