Inventor Forum
iParts Library Path Poll
12 REPLIES 12
Message 1 of 13
310 Views, 12 Replies
A few of us are working on ideas for the iParts Content Library add-in. We
need to know how most people organize their iParts and standard library
parts.
1. In your project path, do you have your iParts more than one level deep?
e.g.
c:\iparts\fasteners
c:\iparts\hardware
is one level deep
c:\iparts\stainless\fasteners
c:\iparts\stainless\hardware
is two levels deep
2. In your project path, do you have your standard library parts more than
one level deep?
(see example above)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
Watch out Philly, Tampa's on a roll...
12 REPLIES 12
Message 2 of 13
jorgen
I was a little unsure if you meant number of instances in project file or directories deep, so here are both:
iParts: Only (1) top directory path in project file, but up to 2 directories deep.
standard library parts (non-editable):only (1) top directory path in project file, but up to 4 directories deep.
Jorgen
Message 3 of 13
Actually both sets of info are helpful.
Everyone please follow jorgen's
example...
Sean Dotson,
PE
Message 4 of 13
This is my structure
C:\Hardware\Screws\ (insert iparts here)
C:\Hardware\Screws\Panhd (child)
C:\Hardware\Screws\Flathd (child)
C:\Hardware\Screws\Truss (child)
C:\Hardware\Connectors\ (both iparts and regular parts)
C:\Hardware\Connectors\12345\ (child)
Kathy Johnson
Message 5 of 13
One level here.
~Larry
"Sean Dotson" wrote in message
news:87EC0CA653E07458AC81284815B2DECC@in.WebX.maYIadrTaRb...
We
> parts.
deep?
> e.g.
> c:\iparts\fasteners
> c:\iparts\hardware
> is one level deep
> is two levels deep
than
> one level deep?
> (see example above)
> Thanks,
> Sean Dotson, PE
Message 6 of 13
One level
Cory McConnell
BJ pipeline Inspection
Message 7 of 13
One level. I don't use a large variety of fasteners and such, so a simpler
scheme works well for me.
WJ
Message 8 of 13
rllthomas
iParts are part of an included project file 1 level deep in the library using proxie paths. Standard library parts are part of the workgroup search path 1 level deep and come from the same included project file.
Rich Thomas
Message 9 of 13
we use just one level. i like to keep it simple. the less paths i have
to choose from the better...
Message 10 of 13
SnellWilcox
Sean,
We use Library paths on the network 1 deep with proxies for iPart Folders. I.E.
Library - f:\_library\Hardware\
_Library - f:\_library\Hardware\Hardware_Parts\
Where individual iParts will be stored under individual Folders under \Hardware\ and any individual parts that make up a manufacturer assy in \Hardware\ are stored in the \Hardware_Parts\ Folder
Hope that helps.
Message 11 of 13
OK guys you can stop now. Charles had a breakthrough. Thanks for the help.
Sean Dotson, PE
Message 12 of 13
Ask and I'll be happy to show you.
[Library Search Paths]
iParts=\\Xen-nas\Physics R&D\_Design\iParts
Library=\\Xen-nas\Physics R&D\_Design\Library
Old Library=\\Xen-nas\Physics R&D\_Design\_Inventor Fastener Library V1
Hal Gwin
Mechanical Designer
Xenogen
Message 13 of 13
I have a folder named g:\hardware
In that folder all my ipart master are put and they create there own folder
in g:\hardware.
e.g.: g:\hardware\nut_master.ipt
create folder and part # like in the
table ->g:\hardware\nut_master\nut_02520.ipt (nut 1/4-20)
This is my std custom library.
bye!
We
> parts.
deep?
> e.g.
> c:\iparts\fasteners
> c:\iparts\hardware
> is one level deep
> is two levels deep
than
> one level deep?
> (see example above)
> Thanks,
> Sean Dotson, PE
