That means that the child is out of date with the parent. Did you try to
place this child when you had the ipart paths in the workspace? If so then
it's probably reference the wrong ipart child. I bet you $ to doughnuts
that if you tried to place a part when you had Fasteners=..//ipart factories
as a workgroup path there is a folder under this directory where the ipart
child is stored. If so then close the assy. Delete this child and folder.
Now reopen the assy with the paths in the library path section and you'll
have to repoint the iparts to the correct children (or if it's just a few
delete them and replace them)
If you didn't place any children while the paths were in the workgroups area
then.....
Was this a new row that was added to the ipart recently? Possibly there is
an error in the ipart table. Can you post it to CF and I'll have a look.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Roger Farstad" wrote in message
news:BFAC411193BFC729A5FA1BB91507B5B7@in.WebX.maYIadrTaRb...
> OK
> I don't know whats happening, but when the users tries to change the size
of
> a inserted bolt, the name changes but the not the fysical model.
> There are also added a ! sign at the beginning of the name of the bolt.
> Roger
> "Sean Dotson" wrote in message
> news:C522CB4DFAEFA3E69C3D350102D6A032@in.WebX.maYIadrTaRb...
> > R6 doesn't prevent you from writing to the proxy path (the _Fasteners
> path).
> > It only prevents changes to the parts in the factory location (Fasteners
> > path). Perhaps you do not have write access on a disk or network level
> that
> > is causing this (external to Inventor). I have my paths set up very
> similar
> > to yours and it presents no read/write problems.
> > Sean Dotson, PE
> > news:1207868F8C7E2779C1FFAA88E123F7F0@in.WebX.maYIadrTaRb...
> > > The problem occure when we try to change the size of the bolts. For
> > instance
> > > from M10x40 mm to M12x60mm
> > > Then you will need write access.
> > > Roger
> > > news:DC815CEFC6F9746E0623649E5C8A0354@in.WebX.maYIadrTaRb...
> > > > Why would you want to move them to workgroup paths for all projects?
> > > > If you want to edit the ipart factories make a new project that
refers
> > to
> > > > the directory as a workspace path...(and keep them as library for
all
> > > other
> > > > projects)
> > > > Sean Dotson, PE
> > > > news:58427D523D7733FBFD6EDB7DC24FB148@in.WebX.maYIadrTaRb...
> > > > > In R5 we did built our own fastener library and added the
following
> > > path's
> > > > > to the project files
> > > > > Library Search path:
> > > > > Fasteners = ....\Fastener_factory
> > > > > _Fasteners=...\Fastener_iparts
> > > > > Our problem is that in R6 all library parts are read only, and if
we
> > > moves
> > > > > the path to Work Group, IV don't understand the _Fastener.
> > > > > Please help, we are stuck on this problem.
> > > > > Roger
