Inventor General Discussion
Valued Mentor
GSE_Dan_A
Message 1 of 7 (310 Views)
iParts and Hole Feature
310 Views, 6 Replies
03-26-2013 09:25 AM
I have created an iPart which uses the Hole Feature (counterbore hole).  The hole is not threaded.  Is there a way to put the Hole Feature into the iPart table so when a user enters specific values, he/she could type in or select a bolt size and the counter bore hole feature will use the correct dimensions for said bolt size (ie.  I would like the counterbore holes for an M6 Socket Head Cap Screw.  So instead of typing in the counterbore hole diameter, depth, and bolt diameter, etc... it would automatically enter the default values.)  Or is this something that must use iLogic?
If you need further information, please ask.  I am using Inventor Pro 2013.  I can post an example of the part if needed.
GSE Consultants Inc.
Windsor, ON. Canada
Hi GSE_Dan_A,
When I had a look at this it dawned on me that just adding a User Parameter called HoleSize or something similar and then making that parameter a key might be all that is needed.
Attached is a simple example, with fictional hole data. Does this do what you need?
I hope this helps.
Curtis
cbenner
Message 2 of 7 (303 Views)
Re: iParts and Hole Feature
03-26-2013 09:44 AM in reply to: GSE_Dan_A
I don't think there is any way to have an ipart prompt for user input.. This sounds like ilogic.  What else about the part can change?  Is it a basic shape and size, and only the hole size changes?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Curtis_Waguespack
Message 3 of 7 (300 Views)
03-26-2013 09:47 AM in reply to: GSE_Dan_A
Hi GSE_Dan_A,
I think we can do this by adding an If/Then in Excel to the iPart table, I'll work up a quick example, but it might be a bit before I get back to it.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Curtis_Waguespack
Message 4 of 7 (282 Views)
03-26-2013 11:00 AM in reply to: Curtis_Waguespack
Hi GSE_Dan_A,
I hope this helps.
Curtis
Valued Mentor
GSE_Dan_A
Message 5 of 7 (275 Views)
03-26-2013 11:21 AM in reply to: Curtis_Waguespack
Thank you both for your responses.
Curis - I think your example will work well! I will give it a go and report back.
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 6 of 7 (245 Views)
03-27-2013 07:57 AM in reply to: Curtis_Waguespack
I may go in a different direction with the Check Fixture.  I was thinking more along the lines of a Form.
User opens Generic Check Fixture Part.
Opens up custom Form.
Enters relevant information.
Part is then created.
Now my question is if I have a Field set-up for Socket Head Cap Screw Size and a drop-down is available to select SHCS size (metric or imperial), how can I get the counterbore dimensions to be linked with the Form?  For example the user selects M8, I would like the counterbore holes to reflect the required dimensions (diameter, depth, etc...)
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 7 of 7 (237 Views)
03-27-2013 08:25 AM in reply to: GSE_Dan_A
Here is my example I am working on.  I have the Form included.  What I would like to have is Hole5 be a drop down within my Form so when the user selects a SHCS size, the counterbore will update with the correct dimensions.
Windsor, ON. Canada
