when i create an ipart with an custom parameter column, the files are created in the workspace.
Is there any way how i can change this location?
Many parts are piling up in the workspace.
For example to the library (like "normal iparts" do) or to a folder in the workspace (workspace/custom_ipart_folder)?
Inventor 2013
Win 7 64bit
Solved by CCarreiras. Go to Solution.
HI!
When you are carrying the iPart member, you can chose the location.
Click "Browse" and select the location you want.
Regards
Is there a way to set a default save path so that I am not constantly retelling the custom iParts where to save? I have tried setting a proxy path but they still default to the root of the project file.
As far as I know there's no where of setting this. I suppose you could set up frequently used subfolders in your project file and then when you save you could select it from the list when you browse. In addition (and I could be wrong).. I don't think proxy folders work anymore in the newer versions of Inventor.
Mark Lancaster
& Autodesk Services MarketPlace Provider
