Inventor Forum
iPart wish - designate workplanes to go thru to child
15 REPLIES 15
Message 1 of 16
203 Views, 15 Replies
I know this has already been lamented by others about iParts, but the only
one that keeps it's workplanes when "being born" is the default size. If the
iPart author intentioned a workplane to assist in the assembly constraining
of the child, this ability currently does not exist. The user of the iPart
must then construct the constraining workplane in each child as he births
them.
I understand an iMate is suggested as a workaround but I can't seem to get
this to work off an added workplane in the factory - the only way I've found
to properly constrain the part. Am I doing somthing wrong? It's that pesky
drill bushing again. I'll post it again in CF. It's getting close but this
issue reared it's ugly head when I went go and use the iPart.
Thanks Many,
Jack
15 REPLIES 15
Message 2 of 16
Check CF under your post.
You have to add the imate properties to the ipart table. It's the third of
fourth tab on the table. When I insert it after making these changes I see
the workplane and iMate glyph.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Jack Brentner" wrote in message
news:F02591E3420217BC16902D477462FCC6@in.WebX.maYIadrTaRb...
the
constraining
> them.
found
> Thanks Many,
> Jack
Message 3 of 16
Thanks very much Sean,
Now it comes in and the workplane is visible. I can turn on the iMate glyph
visibility and perform the mate constraint.
Do you know how to turn the workplane visibility off? It's like some
integral component of the ipart child now and won't go away. Not a big issue
I guess. But there's no item in the browser to right-click on. See
screensnap in CF. I even went back in and made sure the workplane visibility
was turned off in the factory, and retried the ipart in my fixture. Is this
controlled in the table as well?
Thanks Many,
Jack
"Sean Dotson" wrote in message
news:935D315EFE3D2126D473F01BD1AB15FD@in.WebX.maYIadrTaRb...
of
see
> Sean Dotson, PE
only
> the
> constraining
iPart
births
> > them.
get
> found
pesky
this
> > Thanks Many,
> > Jack
Message 4 of 16
If you children are not being saved to a library path you can open the child
created and RMB on the plane and turn it off. If they are in a library path
you will have to change projects or move them out of the path, edit them,
then move them back...
the other (and much easier way) is View > Object Visibility > User Work
Planes. But it turns all planes in the assy off...
Sean Dotson, PE
news:FA27EAD2F037CF9E079267DD4B78A39F@in.WebX.maYIadrTaRb...
glyph
issue
visibility
this
> Thanks Many,
> Jack
> of
> see
> > Sean Dotson, PE
> only
If
> > the
> > constraining
> iPart
> births
> > > them.
> get
> > found
> pesky
> this
> > > Thanks Many,
> > > Jack
Message 5 of 16
Well, I'll be. That did it. Thank you, Thank you, Sean. This puppy's ready
to publish. Should I send it to you or Mr. Bliss?
Thanks Many,
Jack
news:2B2B390463FD34A7CD8CA4910A2D5653@in.WebX.maYIadrTaRb...
child
path
> Sean Dotson, PE
> glyph
> issue
> visibility
> this
> > Thanks Many,
> > Jack
third
> > of
I
> > see
> > > Sean Dotson, PE
the
> > only
size.
> If
> > > the
> > > constraining
> > iPart
> > births
> > > > them.
to
> > get
I've
> > > found
> > pesky
but
> > this
> > > > Thanks Many,
> > > > Jack
Message 6 of 16
Send it to Charles. He's the keeper of the iparts. I just fix 'em
Sean Dotson, PE
news:F9F26A41A9A000329D0A8C8DCF11B9BB@in.WebX.maYIadrTaRb...
> Thanks Many,
> Jack
> child
> path
them,
> > Sean Dotson, PE
> > glyph
> > issue
> > visibility
> > this
> > > Thanks Many,
> > > Jack
> third
> > > of
changes
> I
> > > see
> > > > Sean Dotson, PE
> the
> > > only
> size.
> > If
> > > > the
> > > > constraining
the
> > > iPart
> > > births
> > > > > them.
seem
> to
> > > get
> I've
> > > > found
that
> > > pesky
> but
> > > this
> > > > > Thanks Many,
> > > > > Jack
Message 7 of 16
One last little thing. I posted a snap in CF. Why does my child show 2
embedded spreadsheets - Embedding1 and Embedding2? Embedding1 looks like the
spreadsheet that I started with and Embedding2 is the one with all the
length permutations after I added LENGTH as my #2 key. I can't seem to blow
the old one away. The funny thing is they aren't exposed in the parent for
me to delete either. Is this a bug?
Thanks Many (again),
Jack
news:D19D1BBB45C09B45CD556F94903954FE@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
ready
> > Thanks Many,
> > Jack
> > child
library
> > path
> them,
Work
> > > Sean Dotson, PE
iMate
> > > glyph
big
> > > issue
> > > visibility
Is
> > > this
> > > > Thanks Many,
> > > > Jack
> > third
> > > > of
> changes
> > I
> > > > see
> > > > > Sean Dotson, PE
but
> > the
> > > > only
> > size.
> > > If
> > > > > the
> > > > > constraining
> the
> > > > iPart
he
> > > > births
> > > > > > them.
> seem
> > to
> > > > get
way
> > I've
> > > > > found
> that
> > > > pesky
close
> > but
> > > > this
> > > > > > Thanks Many,
> > > > > > Jack
Message 8 of 16
Are your workplanes always yellow? What color scheme do you use?
~Larry
glyph
issue
visibility
this
> Thanks Many,
> Jack
> of
> see
> > Sean Dotson, PE
> only
If
> > the
> > constraining
> iPart
> births
> > > them.
> get
> > found
> pesky
> this
> > > Thanks Many,
> > > Jack
Message 9 of 16
Yes - see the screensnap "cant turn workplanes off" in CF; I use
Millenium/Gradient.
Jack
"Larry Caldwell" wrote in message
news:23727FDCADB6C90FE4EA16988342733D@in.WebX.maYIadrTaRb...
> ~Larry
> glyph
> issue
> visibility
> this
> > Thanks Many,
> > Jack
third
> > of
I
> > see
> > > Sean Dotson, PE
the
> > only
size.
> If
> > > the
> > > constraining
> > iPart
> > births
> > > > them.
to
> > get
I've
> > > found
> > pesky
but
> > this
> > > > Thanks Many,
> > > > Jack
Message 10 of 16
That's where I saw the yellow workplanes (CF), I'd seen them in other files
and wondered what color scheme produced them. Millennium/Gradient seems to
be the answer. Thanks! (I could have checked it out myself if I wasn't so
gaul-darn-lazy!)
~Larry
news:956F5C1AE59EB85034FE17B00166D731@in.WebX.maYIadrTaRb...
> Millenium/Gradient.
> Jack
> > ~Larry
> > glyph
> > issue
> > visibility
> > this
> > > Thanks Many,
> > > Jack
> third
> > > of
changes
> I
> > > see
> > > > Sean Dotson, PE
> the
> > > only
> size.
> > If
> > > > the
> > > > constraining
the
> > > iPart
> > > births
> > > > > them.
seem
> to
> > > get
> I've
> > > > found
that
> > > pesky
> but
> > > this
> > > > > Thanks Many,
> > > > > Jack
Message 11 of 16
Larry I take that back - my "Orgin" workplanes (XZ, etc) are blue, and my
user workplanes are yellow. Why?
Jack
> Millenium/Gradient.
> Jack
> > ~Larry
> > glyph
> > issue
> > visibility
> > this
> > > Thanks Many,
> > > Jack
> third
> > > of
changes
> I
> > > see
> > > > Sean Dotson, PE
> the
> > > only
> size.
> > If
> > > > the
> > > > constraining
the
> > > iPart
> > > births
> > > > > them.
seem
> to
> > > get
> I've
> > > > found
that
> > > pesky
> but
> > > this
> > > > > Thanks Many,
> > > > > Jack
Message 12 of 16
Right ... I think the origin planes are all blue no matter what color scheme
you pick. I was asking about the user workplanes.
~Larry
news:20CEDABE66530D1B84BDBA9D3F0E9EED@in.WebX.maYIadrTaRb...
> Jack
> > Millenium/Gradient.
> > Jack
> > > ~Larry
iMate
> > > glyph
big
> > > issue
> > > visibility
Is
> > > this
> > > > Thanks Many,
> > > > Jack
> > third
> > > > of
> changes
> > I
> > > > see
> > > > > Sean Dotson, PE
but
> > the
> > > > only
> > size.
> > > If
> > > > > the
> > > > > constraining
> the
> > > > iPart
he
> > > > births
> > > > > > them.
> seem
> > to
> > > > get
way
> > I've
> > > > > found
> that
> > > > pesky
close
> > but
> > > > this
> > > > > > Thanks Many,
> > > > > > Jack
Message 13 of 16
Just saw your post 1 minute earlier than mine . . .
> Jack
> > Millenium/Gradient.
> > Jack
> > > ~Larry
iMate
> > > glyph
big
> > > issue
> > > visibility
Is
> > > this
> > > > Thanks Many,
> > > > Jack
> > third
> > > > of
> changes
> > I
> > > > see
> > > > > Sean Dotson, PE
but
> > the
> > > > only
> > size.
> > > If
> > > > > the
> > > > > constraining
> the
> > > > iPart
he
> > > > births
> > > > > > them.
> seem
> > to
> > > > get
way
> > I've
> > > > > found
> that
> > > > pesky
close
> > but
> > > > this
> > > > > > Thanks Many,
> > > > > > Jack
Message 14 of 16
Or . . . 🙂
Change from Position View to Modeling View - presto! There it is.
Jack
child
path
> Sean Dotson, PE
> glyph
> issue
> visibility
> this
> > Thanks Many,
> > Jack
third
> > of
I
> > see
> > > Sean Dotson, PE
the
> > only
size.
> If
> > > the
> > > constraining
> > iPart
> > births
> > > > them.
to
> > get
I've
> > > found
> > pesky
but
> > this
> > > > Thanks Many,
> > > > Jack
Message 15 of 16
There is an extra (actually just one) embedded Spreadsheet in the original
factory. Delete it and then you'll only have on in each child. There
shouldn't be an embedded sheet in the factory.
Sean Dotson, PE
Check the Inventor FAQ for most common questions
news:7F705A35A37DA723954794D5AA0B2CC7@in.WebX.maYIadrTaRb...
the
blow
> Jack
> > Sean Dotson, PE
> ready
> > > Thanks Many,
> > > Jack
the
> > > child
> library
> > > path
> > them,
> Work
> > > > Sean Dotson, PE
> iMate
> > > > glyph
some
> big
> > > > issue
> > > > visibility
fixture.
> Is
> > > > this
> > > > > Thanks Many,
> > > > > Jack
the
> > > third
> > > > > of
> > changes
> > > I
> > > > > see
> > > > > > Sean Dotson, PE
> but
> > > the
> > > > > only
default
> > > size.
> > > > If
> > > > > > the
> > > > > > constraining
of
> > the
> > > > > iPart
as
> he
> > > > > births
> > > > > > > them.
> > seem
> > > to
> > > > > get
> way
> > > I've
> > > > > > found
It's
> > that
> > > > > pesky
> close
> > > but
> > > > > this
> > > > > > > Thanks Many,
> > > > > > > Jack
Message 16 of 16
How right you are. Not sure how I missed that but thanks. Don't know either
how it got there. That's my story and I'm stickin' with it.
Thanks Many,
Jack
news:6BA86D0C6033ED4ECE3C978EEB18E6E7@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> the
> blow
for
> > Jack
> > > Sean Dotson, PE
> > ready
> > > > Thanks Many,
> > > > Jack
> the
> > > > child
> > library
> > > > path
edit
> > > them,
> > Work
> > > > > Sean Dotson, PE
> > iMate
> > > > > glyph
> some
a
> > big
> > > > > issue
See
workplane
> > > > > visibility
> fixture.
> > Is
> > > > > this
> > > > > > Thanks Many,
> > > > > > Jack
> the
> > > > third
> > > > > > of
> > > changes
> > > > I
> > > > > > see
> > > > > > > Sean Dotson, PE
iParts,
> > but
> > > > the
> > > > > > only
> default
> > > > size.
> > > > > If
> > > > > > > the
assembly
> > > > > > > constraining
user
> of
> > > the
> > > > > > iPart
> as
> > he
> > > > > > births
> > > > > > > > them.
can't
> > > seem
> > > > to
> > > > > > get
only
> > way
> > > > I've
> > > > > > > found
> It's
> > > that
> > > > > > pesky
> > close
> > > > but
> > > > > > this
iPart.
> > > > > > > > Thanks Many,
> > > > > > > > Jack
