When bringing an iPart into an assembly, the window that usually opens and allows you to select the parameters is a bit screwy. I usually can't see the buttons unless I expand the window to be very large, and I always have to increse the size of the columns in order to read what's in the column. In the attached image, there's a value column that I can't get to display.
is there a known bug that I'm unaware of? . . . does a hot fix exist? . . . is this not an Inventor 11 (SP1) issue?
