I've made a component pattern in an assembly using an iPart. The iPart as several different lengths, but I cannot switch lengths in the assembly. In other assemblies, right clicking on the Table icon allows me to change lengths, but this assembly will not.
Solved by Cadmanto. Go to Solution.
Welcome to the forum.
If you created the ipart factory after you inserted it into your assembly then it wont change.
You will have to replace it by RCing on the component in the browser and select "Replace Component".
Then you can switch them.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
