Inventor General Discussion
Active Contributor
SoulAsasin
Message 1 of 12 (399 Views)
Ipart - Standard parameter column change depending on custom parameter column
399 Views, 11 Replies
01-03-2013 02:10 AM
Hello all,
I am triyng to publish to the CC a guide rail. The vendor of the rail gives me the option of entering the desired length of the rail. After that he gives me the option to choose beetween the length that I entered and a shorter and longer standard length witch can be delivered faster.
I want to do the same thing with my published part, but I cannot make a key parameter to change depending on the entered custom parameter. I want the user to make the next steps when inserting from the CC: 1- select the size of the rail; 2-select the type of the rail; 3- enter the dezired length of the rail; 4- choose beetween the desired length and the 2 recomended lengths (I need these 3 lengths to be shown)
Is this possible?
Thanks in advance for the help.
Inventor 2012
Win 7 64-bit
Dell Precision T5400
Intel Xeon 2,5 GHz
8 Gb RAM
NVIDIA Quadro Fx 3700
Active Contributor
SoulAsasin
Message 2 of 12 (370 Views)
Re: Ipart - Standard parameter column change depending on custom parameter colum
01-04-2013 03:59 AM in reply to: SoulAsasin
anybody?
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
Active Contributor
SoulAsasin
Message 3 of 12 (344 Views)
01-09-2013 01:14 AM in reply to: SoulAsasin
I hope somebody answers until 2189. The year I will by my next autodesk product!
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
cwhetten
Message 4 of 12 (332 Views)
01-09-2013 10:30 AM in reply to: SoulAsasin
I'm pretty sure that this isn't possible with standard iPart functionality.  This would not be very hard to do with iLogic, but when you throw the content center into the equation, it gets trickier.  I don't know if it is possible to have iLogic rules in a CC part... I've never tried it.
Can you post your part so I can give it a try?
-cwhetten
Please click "Accept as Solution" if this response answers your question.
Active Contributor
SoulAsasin
Message 5 of 12 (318 Views)
01-09-2013 11:15 PM in reply to: cwhetten
Hey.
Thanks for the reply. I was afraid of this. Oh well.
I attached the rail. It isn't much. I knew that the length generation will be the bottleneck, so it was the first thing I tried.
You can take the section from my part if you want to start from 0.
I guess that if you manage to pull it of with iLogic, I won't be able to use it in Inventor 2010. Right?
Thanks anyway.
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
cwhetten
Message 6 of 12 (308 Views)
01-10-2013 08:07 AM in reply to: SoulAsasin
OK, I'll see what I can do.
iLogic was available in 2010 as an add-on for subscription customers.  If you are on subscription, you can download and install the add-on.  If not, then I guess we will have to see what else we can do.
cwhetten
Message 7 of 12 (296 Views)
01-10-2013 11:20 AM in reply to: SoulAsasin
Is there some kind of logic to the recommended lengths, like maybe they are every 16 mm or whatever?  If there is some pattern to it, it may be possible to do this with a formula.
Active Contributor
SoulAsasin
Message 8 of 12 (284 Views)
01-10-2013 10:13 PM in reply to: cwhetten
Hey.
Thanks for the help.
Attached you have a pdf catalog of the rail. On page 121 you can see how the recomended length is calculated based on the desired length. Hope it helps.
Unfortunatly our company only has the basic version of Inventor so we don't have iLogic. But maybe I can convince them to buy the add-on if we can use it enough.
Thanks.
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
cwhetten
Message 9 of 12 (255 Views)
01-11-2013 11:24 AM in reply to: SoulAsasin
Well, without iLogic, there is definitely no way to do EXACTLY what you want.  However, I have an idea that may be close enough for you.
I am out of time today, but I will write back on monday.
Active Contributor
SoulAsasin
Message 10 of 12 (237 Views)
01-13-2013 10:35 PM in reply to: cwhetten
Hey.
Looking forward to your ideea.
Thanks.
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
