When we place some of our iParts in assemblies, we get glyphs immediately to the left of the factory member name and fhe table, as per the attached. What's happening here, and how can we fix it? Thank you.
It can mean a number of things. Usually means that a reference is missing to something. If you hover over the glyph does it give you any clue what the error is?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
open up the i[art and make sure it is not relying on any external links, if so you may have to remove them.
I just opened it, and I don't think it's relying on external links. I'm attaching it.
Hi! The warning sign usually means either Inventor detects there is an error on the table or the link between the iPart member file cannot find the iPart factory file.
Please open the factory part and right-click on the table -> Edit Table. You will be prompted by a warning message saying a member is not unique. Click Yes to continue. On the iPart table -> click Verify. Scroll to row 86 and row 87. The two members share the same file name. They should be different. After you correct the error, the warning should go away.
Thanks!
Hmm, it seems to me that the file names are as follows:
Row 86: SST, 3/8-16 X 1.125 HHMS
Row 87: SST, 3/8-16 X 1.25 HHMS
Hi! Indeed, the two cell values are different but somehow Inventor thought they were the same. It is possible at one point the two cells were the same and the error status was not cleared out properly. But, I don't have a proof for that.
Try editing the table and run Verify again, do you still see the two cells highlighted?
Thanks!
This is what I see in the table immediately after running Verify. Row 86 has a pale green background. Is that what you mean by highlighting? Thank you.
