Inventor Forum
iPart Part Number
4 REPLIES 4
217 Views, 4 Replies
iPart Part Number
Can some shed some light on how to get iPart fasteners to always produce
their full Part Name in the Part number of the Parts list (such as FHMS 8-32
UNCx5-8).
Example: iPart Fastener FHMS-UNC.IPT yields the exact same Part Number in
the IDW Parts list no matter what size or thread is chosen-very frustrating.
the only work around is to manually fill out the 'Part Number' or
'Description' cell in the Part list & then freeze it (can't override the
Part Number. But this defeats the automation & risks errors if part changes
length & you forget to correct the Part List manually.
How do you control this? So far, I cannot find anything specific in Sean's
tutorial on iParts that allows me to fix this problem on the existing
iParts.
Is there any preferred procedure regarding selecting the child iPart vrs
selecting the parent iPart when adding a fastener to an assembly?
Thanks.
Gary
gcross@crossdesign.com
4 REPLIES 4
I've also noticed that not all my iParts fasteners have this behavior. I
sure would like to know how to fix it on the ones that do. Any help will be
appreciated.
Gary
I think that Sean came up with a solution. Have the part number field in
your Ipart table.
PS this occured in IV6 too
Kathy Johnson
In the iPart table you have to add the Part number column and fill it in.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
When posting Attachments Please Zip first and Use the new IVCF
Web http://discussion.autodesk.com/WebX?14@186.Fx3taaT3ofu.79@.f15ad3a
Newsreader news://discussion.autodesk.com/autodesk.inventor.customer-files
"Gary Cross" wrote in message
news:3EC885DCB9B8927EAFF54B49E0E51C96@in.WebX.maYIadrTaRb...
> UNCx5-8).
yep..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:DA24E09316EDEDD6112D6C422E6E8ABB@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
> Newsreader
8-32
> > UNCx5-8).
