Inventor General Discussion
Valued Contributor
1 Kudo
Post 1 of 9
iPart parameters in iAssembly general table
444 Views, 8 Replies
12-20-2012 10:17 AM
How can I display iPart parameters in an iAssembly general table?
On my .dwg I would like to use one detail with a table.  The 2 table columns I need are:
(1)   iAssembly name (no problems here, shows up in the general table by default)
(2)   Length (this parameter value is in the iPart)
I can't find any solutions to this in the discussion groups anywhere.
Thanks for your help!
__________________________
jlane
Inventor Pro 2015
AutoCAD Mechanical 2015
Advance Steel 2015.1
ASD 2015
Vault Professional 2015
Navisworks Manage 2015
Windows 7 Pro
1,277 Kudos
Post 2 of 9
Re: iPart parameters in iAssembly general table
12-20-2012 10:31 AM in reply to: jlane
You can't control the length (dimension variable) from within the iassembly.
What you are going to have to do is create an ipart of that part with all of the
variable lengths.  Then specify the specific ipart within the iassembly.
Hope this makes sense.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Valued Contributor
1 Kudo
Post 3 of 9
12-20-2012 10:37 AM in reply to: Cadmanto
Yes.  I have that all set up nicley.  Works like a charm.
What I'm trying to do is have the iPart parameter display in a table.  When I place my iAssembly into a .dwg and create a General Table from it, I need the iPart parameters to show up for the fabricator.
Any ideas?  Thanks!
jlane
Inventor Pro 2015
ASD 2015
Windows 7 Pro
1,277 Kudos
Post 4 of 9
12-20-2012 10:48 AM in reply to: jlane
Are you trying to get the parameters from the factory table to basically showup in the drawing in a general table?
If that is the case, take a look at this link.
http://forums.autodesk.com/autodesk/attachments/autodesk/78/421283/1/Custom%20Parameter%20Formatting...
Best Regards,
Scott McFadden
Valued Contributor
1 Kudo
Post 5 of 9
12-20-2012 10:51 AM in reply to: Cadmanto
Yes, that's right.  I hope it's just something simple that I'm missing...
jlane
Inventor Pro 2015
ASD 2015
Windows 7 Pro
Valued Contributor
1 Kudo
Post 6 of 9
12-20-2012 11:02 AM in reply to: Cadmanto
I've attached a screen shot of a simple iAssembly with a general table.  I've added a custom property column called "LENGTH".   All I need now is to get the iPart parameter for "LENGTH" to be displayed.
jlane
Inventor Pro 2015
ASD 2015
Windows 7 Pro
1,277 Kudos
Post 7 of 9
12-20-2012 11:32 AM in reply to: jlane
Did the link in my last posting not give you what you are looking for?
I think it does cover what you are asking.
Best Regards,
Scott McFadden
Valued Contributor
1 Kudo
Post 8 of 9
12-20-2012 12:00 PM in reply to: Cadmanto
Thanks for the White Paper Scott.  Good reference material.  We've got the hang of setting up parameters and iProperties for "Parts List" on .dwgs.
I think my problem is a different scenario.  When a table of the entire iAssembly "factory" is needed, you need to use "General Table" rather than "Parts List".  How can I push the iPart parameter to the iAssembly level?
I've attached a screen shot of the general table for the iPart after I've placed it on my .dwg.  I've added a custom column that matches the name of the iPart parameter I need shown.  Works perfect.  But I need that info displayed at the iAssembly level.
Thanks for your patience...
jlane
Inventor Pro 2015
ASD 2015
Windows 7 Pro
1,277 Kudos
Post 9 of 9
12-21-2012 10:05 AM in reply to: jlane
The only other way I can think of that this might be able to be done is through ilogic.
Unfortunately that is not my fotea.  So I can't help you with that.  That is if you want to keep
this all parametric.  Which I am assuming you are.
Best Regards,
Scott McFadden
