Hi Laura,
iPart children are created from the standard template file and pick up the
origin visibility from that. Two possible solutions for you are:
1) Make the origin planes visible in your template file. If you do this
they will be visible for every new part you create with that template.
2) In your iPart factory, create user workplanes which are coincident with
the origin planes. Then go to the "Work Features" tab on the iPart Author
dialog, add a column to your iPart table for the new work features, and set
the table values to "Include".
Hope that helps!
Tom Sturtevant
Inventor Part Modeling
wrote in message news:4891038@discussion.autodesk.com...
I did a search for this topic but their solutions didn't work for me.
I have an ipart with uses the origin workplanes for placement in an
assembly. These workplanes are visible when in the ipt mode. After
placement in an iam, where my origin workplanes are already set to visible,
the ipart origin workplanes will not display.
How do I fix this? Thanks.
