Inventor Forum
ipart no longer working 2009
13 REPLIES 13
Message 1 of 14
478 Views, 13 Replies
One of my old shaft collar iparts that i've used for years now comes up in
2009 saying "failed to read table". Any ideas?
bl
Brian Land
Mechanical Design
Lorik Tool Inc.
www.lorik.us
13 REPLIES 13
Message 2 of 14
maybe copy the table in excel into the new part file from the old one?
Message 3 of 14
how do i get to the table to copy it? When i try to access the table
through the part it tells me it can't open it.
wrote in message news:5919575@discussion.autodesk.com...
Message 4 of 14
Post your iPart, zipped.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
"BL" wrote in message
news:5919862@discussion.autodesk.com...
Message 5 of 14
BL,
Did you happen to have Excel open and have a cell with focus (dbl click in
the cell)? This will cause what you are seeing. Esc to lose focus in Excel
and try again.
Rich Willis (Autodesk)
"Dennis Jeffrey" wrote in message
news:5919894@discussion.autodesk.com...
HP zv5000 AMD64 2GB
Message 6 of 14
I've not had the excel sheet on this part open in years.
thanks,
bl
"Rich Willis (Autodesk)" wrote in message
news:5920304@discussion.autodesk.com...
BL,
and try again.
HP zv5000 AMD64 2GB
Message 7 of 14
I mean Excel stand alone. Any Excel file, not the one associated with the
part.
news:5920412@discussion.autodesk.com...
thanks,
bl
BL,
and try again.
HP zv5000 AMD64 2GB
Message 8 of 14
thats not the problem here, no excel files open, the part is bad on every
machine i've tried to open it with here. The only mod that I know that has
happened to the part is it being migrated to 2009
bl
news:5920457@discussion.autodesk.com...
part.
thanks,
bl
BL,
and try again.
HP zv5000 AMD64 2GB
Message 9 of 14
His part is bad here also. The only option available is to delete the table.
BL,
Do you have the older non-2009 version??
HP zv5000 AMD64 2GB
part.
thanks,
bl
BL,
and try again.
HP zv5000 AMD64 2GB
Message 10 of 14
Yesterday i pulled up the old version of the part and the table still
worked, I restored the old version to current and the table is bad again. I
got in my backups and pulled another copy which worked fine, saved it and it
still is looking okay. No clue what killed it.
thanks,
bl
Brian Land
Mechanical Design
Lorik Tool Inc.
931-762-3495
www.lorik.us
news:5920703@discussion.autodesk.com...
BL,
HP zv5000 AMD64 2GB
part.
thanks,
bl
BL,
and try again.
HP zv5000 AMD64 2GB
Message 11 of 14
johnsonshiue
It sounds like the Excel on the machine is not being recognized by Inventor. Could you perform a repair install of Excel with Inventor shut down?
Thanks!
Johnson Shiue
Inventor QA Tech Lead
johnson.shiue@autodesk.com
Software Test Engineer
Message 12 of 14
Johnson, it's not that... My system exhibits the same result with his part.
My system works fine with iParts, etc....
HP zv5000 AMD64 2GB
wrote in message news:5921228@discussion.autodesk.com...
Thanks!
Johnson Shiue
Message 13 of 14
same thing on all our machines here...
Brian Land
Mechanical Design
Lorik Tool Inc.
www.lorik.us
news:5921266@discussion.autodesk.com...
HP zv5000 AMD64 2GB
Thanks!
Johnson Shiue
Message 14 of 14
johnsonshiue
Do you still have the iPart before saving in R2009? Please send it to me.
Thanks!
Johnson Shiue
