I have made an Ipart family for our electrical motor. I've publish them in a content center library. My problem is that the weight doesn't match with the real one. I search a solustions to override the weight of each member of my family. Does someone have any solutions about this problem.
Thank a lot.
There might be an ilogic solution, but I don't use that very much so I can't offer one. Maybe you add a custom iprop to the factory table that stores the mass for each member and add a rule that overwrites the member mass with the value from the custom iprop.
I can think of two non-ilogic solutions to this problem.
1. Create a custom material for each member that has a density value that gets the correct weight for each ipart member.
2. Add an internal void to the factory and adjust its size until you get the correct weight for each ipart member.
Steve Walton
This is hard to speak to from this end.
All I can tell you is the weight is based on the density of the material you select. If the density of the material you selected matches the real life part, then it should match. Is this material selected a custom material you placed in the material library or did you select one from the out of the box materials inside of Inventor?
The fact that they are in the CC has nothing to do with weight. Were they correct prior to publishing to the CC and that is the premise of your question?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You can override the Mass of any Part or assembly by entering to the iProperties.. I show it with a picture..
I dont know if you can do this once the part is published
Yes, I know that can be done, but in my opinion, this is not a solution, but just a bandaid and mask of what the true root cause is. The software is supposed to do this automatically and if there is an incorrect value, then something like the material specs need to be altered.
Of course, If your design is 100% true, and all the materials are set correctly the weight should be correct one.. But in many situations your 3D data came from brochures or similar... So you design an empty shell with general dimension and then override the weight,, for example if you are using an electric motor in an assembly, and you take the dimensions and weight from the Web page of the manufacturer, you can use this method..
Does someone have a solution for this? I have the exact same problem as the last commenter. We have an imported part that represents an non-homogenous assembly. We typically use a mass override to get the right value, but this gets lost when using an iPart family -- the resulting mass is just volume * density. Why can't iParts also override the mass?
A single part or iPart representation of an assembly won't produce the correct Mass or C/G of the part. You can override the Mass of the part in the iProperties tab which will then reflect the correct Mass. This won't help with the correct C/G location of the part or any assembly that this part resides within.
I guess you could also override the C/G coordinates as well and enter in user defined ones for the X, Y, Z values.
Just change the calculated values and remember not to click on the Update icon in the Physical Tab of the iProperties.
Each time you place an iPart the value is updated. I think I might just create all the different combinations of this unit as standard parts and override the Mass and C/G coordinates if you want accurate assembly values.
How can I override the mass of a multi-body ipart and have that persist into an iPart instance?
I am trying to create a library iPart that's based on an electric gear motor model. The gear motor is a complex, multi-density item. The representational model is just a single part, so we override and enter the correct mass (CG will differ, but that's OK). We want to have multiple versions of this motor that change nothing about the physical model -- only the model numbering (for different vendor options: motor winding, encoder type, etc.). Unfortunately, our solution to use iPart seems to suggest we cannot use mass overrides -- without fudging to get the mass right (creating a custom density, or creating an internal cavity). What are other people doing here?
Note: overriding the mass at the next assembly is not a viable, long term option.
I have same problem, I clicked on iProperties >> Physic >> but I couldn't see the "user override value" botton at the right side of mass box, my program only have calculate value botton.
What wrong with my program? Everyone can help please?
Thanks a lot
It used to be the center "hand" icon. Now just click the calculator icon to the RH of the Mass box to recalculate and then change the displayed value with your manual entry. This will over write the value with your manually entered value.
I have a lot of problems with this once I update to content center but set a custom parameter "Weight" and add this iLogic. Add to a trigger that it updates on open or parameter change or something like that.
Works like a charm for non published parts. Gives grief once you publish but still technically works.
iProperties.Mass=parameter("Weight")
Please see below to see if this solves what you are trying to do. There is reply with a "p1.ipt" that might be what you are looking for. Hope it helps
https://forums.autodesk.com/t5/inventor-forum/adding-mass-overides-to-iparts/td-p/3267778
