wrote in message news:6340604@discussion.autodesk.com...
Thanks walt.
I have been experimenting with imputing a formula in to the rectangular
pattern.
I cant open the part from your other post, I get the error "Database schema
is newer than this version of the software." . I am on 2009 educational
version so there may be a compatibility issue.
Can you use the same type of formula as in excel.
If it is possible I will crack it.
Thanks again
James
_________________________
I'm running 2010, and Inventor files aren't backwards compatible, so you
won't be able to open the file. Here's a screen capture that shows the way
the part was set up. Not all of Excel's formulas are available in the
parameters dialog. Look up "equations, edit box entry" in the help files to
find out what's available in Inventor.
Cheers,
Walt
