I had an established released door dwgthat I cioied back to use to create additional versions with ipart factory.
I have found it disturbing that I called up the part drawing from the original part and saw that the factory had changed the part in the drawing to the new wider part. It seems that as long as Ipart factory part is open which ever part is active will replace the part in the drawing when it is called up (no matter what the part naming convention says). I don't unerstand this function. Need help.
edit base view on the idw, go to the model tab and change ipart member to the member you want in the drawing (not active factory member)
@Anonymous wrote:
Mine isnt allowing me to change the part,they are all the same part?
Can you post a screenshot of what you see on that tab when you edit the base view?
Have you generated all the members? (right click on all the members in your ipart factory and hit generate)
@Anonymous wrote:
where do I go to generate the model....that's probably why it isn't working
-Jonathon Wood A-101
See attached image
try creating a new drawing now that you have generated the members and see if it works..
Inventor has a nasty bug with drawings not showing updates properly with iparts.
post the ipart
I don't need the members..just the factory ipt
@Anonymous wrote:
you want me to post the part itself?
yep.. and tell me what version of Inventor you are using
Sorry, I had to check with my boss haha he doesn't like the idea of it just floating in cyberspace haha
works just fine for me..
See attached
and you are aware you have many missing dimensions right? this part is NOT fully constrained at all. Not that it really matters but its NEVER a good idea to create parts that aren't fully constrained
oh wait..now I see what your real problem was..
The part is not changing its "Length" parameter when switching members.. It "seemed" like you were having a problem where all members were showing the same member name in the member selection box..
Give me a second to see why
ok.. Its just because you dimensioned that "length" parameter to a construction line and then nothing is referenced off that construction line so the length isn't changing. So it really is missing dimensions that is causing the problem..
I don't need it in a dwg, but I am aware I can select a different size, but the part is the visually the came part to part. this is where I have the issue, try it in this assembly, but I might have it wrong. The goal here is I need the hinge (and part name and number) to change upon a certain range on doors that I have controlled via an excel file. so if I plug in dimensions like an 80"x32" door, I need the 30" strap to be placed on the door in the correct location. but if I say read the munber wrong and it was a 36" wide door, I need the straps to reflect that.... Does this make sense? Is it even possible?
I just edited my post so see right above for the cause
well here it is
mcgyvr
Now go back into your first sketch and 100% constrain everything and it works just fine. It changes length when you pick each different member.
frankly thats just a mess of poor sketching/dimensioning (no offense).
start over IMO..
