I have created an engraved plate which fits around a pressure gauge. The engraved text could potentially read anything you like so I created it as an iPart. The iPart table allows you to pick what text you want when you insert in an assembly. The text options are obviously pre-defined.
The thing I am unable to do is actually get the text on the item.
In the part, if I create a sketch then insert text I have no way of linking to the iPart spreadsheet or inserting text from the iProperties.
Anyone got any ideas?
Ross
