Inventor General Discussion
Valued Contributor
randym1982
Message 1 of 5 (130 Views)
IPart Dimension to unresolved reference geometry error
130 Views, 4 Replies
09-02-2009 07:58 AM
I am having trouble with Iparts getting a red cross due to dimensions and constraints to unresolved reference geometry. If, for example, I have Hole 2 dimensioned from Hole 1 in one member and in another member I suppress Hole 1 and Hole 2 I get an error stating (correctly) that the sketch for Hole 2 has a "Dimension to unresolved reference geometry". I understand why I should get this error if Hole 2 was unsuppressed and Hole 1 was suppressed but why do I get this error when they are both suppressed.
If I get this error on a member that has these two holes suppressed and I switch back to a member that has them both active the error dissapears. I guess in the end this is a question for Autodesk. Can you set up Iparts so that when a feature is suppressed Inventor completely ignores it instead of still trying to resolve it. This functionality is a major headache for us because we don't want to leave models with the Red Cross on but if we want to dimension our features appropriately (ie referencing other, related features) we have to leave a model with errors in it.
Please see my attached part with this issue. If you switch within the first 2 members there are no errors, if you move into the last 2 members you will see the cross highlight.
Active Member
billbrenner4604
Message 2 of 5 (101 Views)
Re: IPart Dimension to unresolved reference geometry error
03-19-2012 08:30 AM in reply to: randym1982
I've been using Inventor for about 6 years now and this positively drives me insane. Has anyone (cough...Autodesk) come up with a solution for this issue? You can go in and re-dimension your sketches, but more often than not, you end dimensioning to something you really don't want to just to get rid of an error that shouldn't be there in the first place.
Distinguished Mentor
IgorMir
Message 3 of 5 (91 Views)
03-19-2012 06:32 PM in reply to: randym1982
Hi Randy,
I don't think you will get an answer from Autodesk any time soon. What you should do in a mean time is to avoid projecting model geometry in iParts. Project sketch geometry instead. Some times it is feasible to create a Shared Sketch and use it to control the features you need.
Here is a modified part for you.
Best Regards,
Igor.
Web: www.meqc.com.au
Active Member
billbrenner4604
Message 4 of 5 (83 Views)
03-20-2012 03:30 AM in reply to: randym1982
Thank you for your help Igor. But really, Autodesk should be embarrassed by forcing users to not use model geometry as references in i-parts. If only some other software company had already figured out that suppressed features should also suppress the associated sketch.
IgorMir
Message 5 of 5 (80 Views)
03-20-2012 03:43 AM in reply to: billbrenner4604
The list of "embarrassing" things in Inventor is called by Autodesk a Wish list.:smileylol:
Igor.
