Inventor General Discussion
Product Support
Daren.Lawrence
Message 11 of 20 (754 Views)
Re: iPart creation error message - Failed to Export Desel Table
11-08-2011 06:28 AM in reply to: dgthe3
Please see the following solution. Any call to MS Excel from an application on W7 64 bit will have this issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079866&linkID=9242018
Please mark as solution if this resolves your issue. Thank you.
Daren Lawrence
Product Support Specialist
MFG Support - Inventor
http://beinginventive.typepad.com/being-inventive/
New Member
kegu1608
Message 12 of 20 (671 Views)
01-09-2012 12:30 AM in reply to: stevec781
Hi.
I got the same problem, " Failed to export desel table".
As it says in the tread i tried to install microsoft excel but that didnt helped at all.
I then tried to do the fix in the register, but i dont even have the "folder" "{ 00024500-0000-0000-C000-000000000046}" .
the closest i got is { 00024512-0000-0000-C000-000000000046}. I tried to edit this and delete all the Wow6432Node\  but that didnt worked either. So i imported the original register file.
Any sugestion?
Valued Contributor
cean_au
Message 13 of 20 (655 Views)
01-14-2012 07:53 PM in reply to: Daren.Lawrence
not workong under win xp.
Member
jbvdveen
Message 14 of 20 (641 Views)
01-20-2012 02:08 PM in reply to: stevec781
I am  having the same problem even thogh i installed excel
Active Member
mwardas
Message 15 of 20 (608 Views)
01-29-2012 05:13 PM in reply to: jbvdveen
I don't have the registry file listed.
Please help!!
Member
jbvdveen
Message 16 of 20 (602 Views)
01-29-2012 10:00 PM in reply to: Daren.Lawrence
I am having the same problem too. No file of that name in the registry editor in Windows XP!!!
PLEASE HELP!!!!
Member
jbvdveen
Message 17 of 20 (600 Views)
01-29-2012 10:02 PM in reply to: Daren.Lawrence
Please. Help!!!!! I do not have even that file in the registry editor in Windows XP!!! HELP PLEASE!!!
Active Member
mwardas
Message 18 of 20 (592 Views)
01-30-2012 09:35 PM in reply to: mwardas
problem resolved after installing Office Professional 2010.
Thanks for all of the comments.
Cheers,
M.Wardas
Member
serban.dumbrava
Message 19 of 20 (415 Views)
09-24-2012 04:49 AM in reply to: stevec781
Any other solution found for this problem?
New Member
contato
Message 20 of 20 (232 Views)
04-09-2013 03:57 PM in reply to: stevec781
Autodesk should consider detaching its needs for ms products, the market has so many options nowaday.
http://www.paulobelesa.com.br
skype: pfbelesa
Core I7 2600K - 16GB Ram - 5TB HD - 01 GTX 295 + 01 GTX 460
