running inventor 2010 and open office, is there allready a solution. seems that instaaling office would not solve the problem and i rather would stick with open office
I received the same error. I knew inventor needed excel so I got just got the trial version of Microsoft Office and installed it before I installed inventor. I did have Open Office, but when I first got that error I uninstalled Open Office (leaving Microsoft Office), tried again and nothing. I then removed Inventor and reinstalled it. Still get 'Failed to export Desel Table' after trying to make an iPart. Anyone have any solutions?
Please see the following solution. Any call to MS Excel from an application on W7 64 bit will have this issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079866&linkID=9242018
Please mark as solution if this resolves your issue. Thank you.
Hi.
I got the same problem, " Failed to export desel table".
As it says in the tread i tried to install microsoft excel but that didnt helped at all.
I then tried to do the fix in the register, but i dont even have the "folder" "{ 00024500-0000-0000-C000-000000000046}" .
the closest i got is { 00024512-0000-0000-C000-000000000046}. I tried to edit this and delete all the Wow6432Node\ but that didnt worked either. So i imported the original register file.
Any sugestion?
I am having the same problem too. No file of that name in the registry editor in Windows XP!!!
PLEASE HELP!!!!
Please. Help!!!!! I do not have even that file in the registry editor in Windows XP!!! HELP PLEASE!!!
problem resolved after installing Office Professional 2010.
Thanks for all of the comments.
Cheers,
M.Wardas
