Inventor Forum
iPart creation error message - Failed to Export Desel Table
23 REPLIES 23
Message 1 of 24
stevec781
4185 Views, 23 Replies
Hi All
Can anyone tell me what this error message means. I cant find any reference to it in the help files.
Steve
23 REPLIES 23
Message 2 of 24
NeilClasby75
in reply to: stevec781
Hi Steve
Have you got Excel installed?
I got this error when I had not yet installed Office.
Inventor needs Excel for iPart tables. Without Excel iParts are not possible.
Regards, Neil.
Message 3 of 24
stevec781
Thanks Neil
No I use Open Office.
Looks like I'll have to get my cheque book out
Message 4 of 24
NeilClasby75
dont' forget it is cheaper to upgrade office than buy the full version, and that MS Works can be purchased and then upgraded from, which is much cheaper. This is legal, although not quite sure why MS allow it!!
Message 5 of 24
BrentBaillie
Does it matter which version of Excel I have. I am currently using Excel2000
Message 6 of 24
I'm in the same boat. New Workstation, and OpenOffice works great, so I didn't bother with installing Microsoft Office. Looks like I won't be using iPart tables...
Message 7 of 24
In fact, I'm not sure why Excel is required at all. OpenOffice reads and writes Excel, so it's not necessary to have Excel installed in order to create an Excel file. And OpenOffice is the default program used for XLS files on my computer. Just write the file and let me open it however suits me.
Message 8 of 24
I am getting the same message and am running inventor 2010 with windows 7 and office 2007.
Message 9 of 24
running inventor 2010 and open office, is there allready a solution. seems that instaaling office would not solve the problem and i rather would stick with open office
Message 10 of 24
dgthe3
I received the same error.  I knew inventor needed excel so I got just got the trial version of Microsoft Office and installed it before I installed inventor. I did have  Open Office, but when I first got that error I uninstalled Open Office (leaving Microsoft Office), tried again and nothing. I then removed Inventor and reinstalled it. Still get 'Failed to export Desel Table' after trying to make an iPart. Anyone have any solutions?
Message 11 of 24
Daren.Lawrence
in reply to: dgthe3
Please see the following solution. Any call to MS Excel from an application on W7 64 bit will have this issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079866&linkID=9242018
Please mark as solution if this resolves your issue. Thank you.
Daren Lawrence
Product Support Specialist
MFG Support - Inventor
http://beinginventive.typepad.com/being-inventive/
Message 12 of 24
Hi.
I got the same problem, " Failed to export desel table".
As it says in the tread i tried to install microsoft excel but that didnt helped at all.
I then tried to do the fix in the register, but i dont even have the "folder" "{ 00024500-0000-0000-C000-000000000046}" .
the closest i got is { 00024512-0000-0000-C000-000000000046}. I tried to edit this and delete all the Wow6432Node\  but that didnt worked either. So i imported the original register file.
Any sugestion?
Message 13 of 24
cean_au
in reply to: Daren.Lawrence
not workong under win xp.
Message 14 of 24
jbvdveen
I am  having the same problem even thogh i installed excel
Message 15 of 24
mwardas
in reply to: jbvdveen
I don't have the registry file listed.
Please help!!
Message 16 of 24
jbvdveen
I am having the same problem too. No file of that name in the registry editor in Windows XP!!!
PLEASE HELP!!!!
Message 17 of 24
jbvdveen
Please. Help!!!!! I do not have even that file in the registry editor in Windows XP!!! HELP PLEASE!!!
Message 18 of 24
mwardas
in reply to: mwardas
problem resolved after installing Office Professional 2010.
Thanks for all of the comments.
Cheers,
M.Wardas
Message 19 of 24
serban.dumbrava
Any other solution found for this problem?
Message 20 of 24
Autodesk should consider detaching its needs for ms products, the market has so many options nowaday.
