Inventor Forum
Involute Spline
4 REPLIES 4
lis_wang
811 Views, 4 Replies
Involute Spline
I created a Involute Spline in a assembly. However the Involute Spline at rotor is always over shot. Please see circle indication A in the rotor.png file. I attach my assembly file here. Please help. Thanks
4 REPLIES 4
JDMather
in reply to: lis_wang
What size cutter are you going to use?
lis_wang
I just realized the radius is the cutter size. I soluved my problem.
Thank you very much
JDMather
Don't just make up a size though.
Use an off-the-shelf size.  It may turn out that you cannot avoid the over-cut.  You might add a Chamfer to that edge.
lis_wang
in reply to: JDMather
Is there standard cutter size?
