Just loaded Inventor 2012 on a new computer. It seems to work OK, I can open and close files with no problem, but as soon as I try to shut Inventor down It lock up. The only way to shut it down in using task manager. After I try to shut it down the normal way Inventor continues to consume memory, (memory usage reported in the task manager continues to increase in size)!
Also once it is terminated in task manager and then restarted, the Inventor memory usage reported in the task manager continues to increase in size with no files loaded? Never leveling off. I have monitored it for several minutes after starting it and it continues to steadily increase in memory usage.
Has anyone seen this before?
Solved by blair. Go to Solution.
Just leave it, there have been some instances of slow internet connections and Inventor hanging as it's trying to download updates.
Search this forum on Inventor Hanging.
